Eastside3":aq164lqw said:
For those who keep their boat in the water all year, I’m curious if any of you forego the winterizing of the fresh water tank and holding tank. I like to use my fresh water for drinking so I’d like to avoid RV/Marine antifreeze if possible. It’s been suggested to me that some owners in this area actually just use a heater in the engine compartment and another couple heaters inside. I’m mindful that keeping a boat in the water year round means the systems under the waterline won’t be subject to the freezing temperature that a boat in dry dock would. Nonetheless I’m curious if any others simply use heaters rather than draining or using antifreeze.
We are new to the PNW and also new to our 2015 Cutwater CB 30 (diesel). We are keeping her in the water also and plan to use her throughout the winter, weather permitting.
Our plan based on what I have read here and trawlerforum.com with respect to mild winters in the PNW, is as follows:
1. Install 2 Air dryers
https://amzn.to/33cCTau, 1 in forward berth and 1 in main cabin. These dryers reduce humidity in addition to raising the internal temperature and keeping it well above freezing.
2. Drain water from fresh water system, no antifreeze added. Leave hatch above fresh water tank/water heater open when boat is not in use in order to share warmer temps from main cabin.
3. Keep holding tank empty when boat is not in use. Keep door to head open to share heat from main cabin.
4. Install Caframo engine compartment heater
https://amzn.to/2VzGWeB which will keep engine and most raw water pumps, strainers and plumbing well above freezing.
5. Keep fuel tank full of diesel to reduce chance of condensation and treat fuel with
https://amzn.to/2oq0yFF and
https://amzn.to/35kKJ3w
I feel good about this plan. But, I would be interested in what others who keep their boats in the water in the PNW have to say as well.
