Wiper motor for 2022 31CB
Salty Gal
C-302 SC
Scout
Is the wiper motor for a 2022 Ranger Tugs 31CB a Marinco part number 36161, AFI 1000. 65 deg 1 1/2” shaft as you replied recently to another post on another model manufactured by your company? Or, is it a different part number and spec, and if so, can you please let me know?
My motor failed recently on a rough passage where I was using all four wipers intermittently, and the light on the switch stayed on even though I turned it off, and the motor assembly got hot (measured over 130 degrees 10 minutes after system shut down following the passage). I couldn’t troubleshoot sufficiently enough while underway to disable power to the affected circuit as I could not determine the electrical path to that particular circuit-any info on that path would be appreciated.
I plan to remove and replace the motor once I obtain the replacement part number. Thank you!
Thank you for your reply. New question…how do I remove the old motor? I removed the wiper blades and nut on the outside, removed the wood panel behind the flip down TV and the screw on the left side of the motor on the inside, removed the padded moulding on the ceiling, but the motor does not have enough clearance to be removed in order to replace it. Does the wood ceiling above the TV need to be removed as well? It looks like it cannot be removed easily if at all, and if so, would not drop down because the side moulding inhibits removal. Any thoughts where I go from here? Thank you!
The wood panel would need to come down. The cutout for the wiper motor could be ground out a little for a easier change later if needed.
