V VitaminR Member Joined Sep 2, 2024 Messages 11 Fluid Motion Model R-27 (Outboard) Hull Identification Number FMLT2726H920 Vessel Name VitaminR Sep 2, 2024 #1 How can you get to set screw on shaft once motor is mounted ? Also the wiper blade won’t stay tight to windshield after one revolution. Tips?
C ConnorDietz Factory Employee Joined Oct 28, 2020 Messages 17 Fluid Motion Model C-24 C Oct 22, 2024 #2 Hey there, There is a grey plastic cap that swings out from the window on the shaft. The allen head set screw is under that plastic cap. The metal wiper arm can be bent a bit so the wiper blade is tighter to the window.
