Rocky Lou
- Aug 2, 2019
- C-302 C
- Sea Suite
I am wondering if my calibration is correct.
For example, I filled tanks completely so they should have about 300 gallons. I ran 25-30 miles and Info Station says I have 235 gallons. There is no way I used 65 gallons running under normal conditions. Also, my Garmin says I still have 265 gallons which is about right since I was getting about .9 GPH during running.
I've read that the Yamaha Info station reports 10% less than what is in the tanks to hold a reserve. Hence, if I add 10% (30 G), then the Info Station matches the Garmin Remaining Fuel.
Doing a recalibration is not straightforward, for me anyways, since the manual says you need an empty tank.
