Sunart
- Feb 5, 2025
- R-23 (Outboard)
- FMLT2326I617
- Sunart II
I’m sure this will spark a lot of discussion but I just have one question! I live in the PNW where water temps are typically above 40F in the winter. The boat will be in the water all winter.
The question is about cooling water. (The rest of the Yamaha process will be followed)
I flush the motor with fresh water after every use. I have read the Yamaha instructions about draining the cooling water and it involves tilting the motor up and then fully down to drain the water. Apparently, water is retained inside the engine cooling passages if the engine is left tilted up and could freeze.
I have heard two approaches to winterization:
1) Flush with fresh water and then run the engine in the trimmed up position for a minute to expel the water!
2) Don’t flush. Leave the engine down so that it’s in salt water that shouldn’t freeze!
Neither approach seems ideal. I’m also considering using and air compressor to blow out the fresh water like you do with RVs.
Thoughts would be appreciated.
