Lobo
- Dec 10, 2008
- C-248 C
- FMLT2562J708
- Lobo
I had an interesting failure on my 110 Yanmar. Boat is 8+ years old, always in salt water, and just under 1,900 hours on the engine.
Oil in my bilge this morning, and only a quarter of an inch on my dipstick. Oil and filter had been changed 6 engine hours before. As there had been a lot of work on the engine the week before (injectors, water cooler, all consumables replaced, etc) I called mechanic.
He found a steel tube (5/8" diameter -- about 16" long) on the port side that allows oil to drain from the top of the engine into the sump. Secured to the rear of the motor with a flange and at the front end with a short hose to an outlet. Hose didn't have clamps as there is no pressure -- it's just a drain. The problem was that about 4 or 5 inches from the hose the tube had rusted through and oil was not returning to the sump, but to the bilge. The cure was simple once found: cut the tube short and replace the original 4" hose with a longer one (about 15") 5/8" (inside diameter) and add a couple of clamps. I have no idea why an oil tube can rust out -- but I've got the scrap metal in a ziplock to add to my collection of unusual boat stuff.
Dave
LOBO
I think I was lucky that I still had oil in the sump and found the problem before I started up the engine.
Dave
LOBO
