Brian B
- Apr 19, 2012
- C-26
- FMLR2512L910
- Non-Fluid Motion Model
- Sold in 2021
- GANSETT RANGER (2010) Yanmar 4BY2-150
2010 25SC 4BY2-150 Yanmar with 500 hours. I discovered an oil leak when we returned to the boat and could smell oil in the cabin after a 4 hour trip in FL. I removed both engine covers and with the engine at idle could see oil seeping out of a threaded hole. I removed one of the bolts from the bracket that holds the oil sensor and was fortunate that it was the same size, I screwed it into the hole and the oil leak stopped. The pictures are looking at the front of the engine block with the engine covers removed. Oil was seeping out of the hole that the red arrow is pointing to. The stud and nut to the left of the arrow holds the starboard engine cover. With the help of Mack Boring and Winter Island Yacht Yard in Salem MA it was determined that the only thing missing was a bolt. Apparently this would be used on a different application for the engine.
M8 1.25 bolt and flat washer along with LocTite was used for the fix. So far I have not found the original missing bolt. Also there was very little oil lost, I caught this in time.
