henningbuus
- Apr 26, 2018
- C-302 SC
- FMLT2926B010
A few months ago I lost all the engine oil while running at high RPM. The Yanmar 6BY2-260 is made by BMW and Yanmar converts it to a marine engine. In that process, an engine oil pressure sensor located below the oil filter and pretty much out of sight, is not being used in the marine application. That sensor had unscrewed itself and the oil pump just ejected all the oil into the bilge. Now I am worried that the engine bearings suffered some damage, so I recorded the oil pressure at various rpms and engine temperatures, and would like to know if this is normal. They are as follows:
Engine rpm engine temperature Oil pressure
1200 116 33
2000 182 31
3500 194 45
3500 202 40
3000 204 35
2500 203 23
2000 199 18
1500 197 16
1000 196 11
670 195 7
The Yanmar Service Manual specifies 51 - 87 psi at 4000 rpm, and 8.7 - 14.5 at 1000 rpm, so it appears that my engine meets that, but 7 psi at idle seems very low, and I belive the oil pressure warning comes on at 6 psi.
I would be interested in knowing if any of you with this engine have similar oil pressures.
1200 116 33
2000 182 31
3500 194 45
3500 202 40
3000 204 35
2500 203 23
2000 199 18
1500 197 16
1000 196 11
670 195 7
