jimbeam
- Aug 21, 2019
- C-248 C
- FMLT2545G708
- waite & sea
R25 2008. On the panel their is a row of images. One is a fuel pump image. This lights up and sounds an alarm on occasion for brief periods. I think it means water in the 2nd filter and that sensor is activating. I checked for water and found none. Also checked the racor filter and no water. Is the sensor bad? If any water in the filter shouldn't the primary racor filter pick it up 1st? I ordered the sensor that goes on the bottom of the 2nd filter just to eliminate a bad sensor. Next is to drain the fuel tank. Engine is a 4jh4 hte 110 hp diesel.
jimbeam
jimbeam
