Yanmar i5601E Engine Interface
LADYBUG TOO
C-288 C
FMLT2916B909
LADYBUG, TOO
Ladybug, Too (FMLT2916B909) is equipped with the i5601E display and the 18140P 6BY Engine interface. I have been trying to locate a manual for the display and interface but have been unable to find one. The Teleflex site no longer references an "i5601E" nor the "18104P 6BY" Interface so I am looking for a source to get the manuals. This is original equipment, installed by Ranger so my hope is that somewhere in the factory archives this information is available. Without the pin codes for the wiring harness we are having to trace each harness wire and it is painstakingly slow. We have start function and alarm codes and can run the engine in safe mode. A manual or manuals related to the above interface would be helpful.
Pat, Ladybug, Too
I had trouble finding anything regarding the display too. Andrew pointed me to this post. There's a PDF of the manual there. I hope it's what you need.
Dave
viewtopic.php?f=7&t=1113
Andrew, I am also looking for a manual for my Yanmar I5603E Display - I see you posted a copy of the I5600 manual from Yanmar - seems identical to the Teleflex I5600, but quite different than the I6503I installed on my Ranger 25 (2010).
If you have a pointer to the I5603E, I would appreciate it. Thank you
I see this link kindly provided by "linedoctor" Dave is for the Yanmar 150 HP & 260 HP models.
Not having ready access to our 2011 Ranger '27 w/ the Yanmar 180 HP model, does anybody know exactly what interface Yanmar used then for the 2011 R27's, and if so, does anybody have a manual for that model similar to this one for the 150/260 HP models?
Perhaps you also have this reference Andrew?
Thanks for any such input on the matter and have a good day!
Regards,
Dan, Tanya, and Hannah (the boat dog) Denver
I have a PDF of the Yanmar i5601E ECM manual, if you would like to send me an e-mail address.
Although it would be a lot easier if I know how to attach it to this reply. :shock:
The Yanmar i5600 Engine Display and associated Garmin MFD is calibrated to show engine RPM from 0 to 5000.
Our 2010 Ranger 25's 4BY2150 has a max RPM of 4000. I have reset the range of the tachometer in the I5600 to 0-4000 several times to correspond with the engine - and it reverts to 0-5000 RPM each time it is powered off.
How do I save the calibration settings? Thanks.
