Zinc
danielosurf
C-24 C SE
BC148422
Winelight
Hello there I'm just about to get the bottom of my 2007 21 EC cleaned up and will get all the zinc replaced.
I'm just trying to get the parts # or type for the anodes (prop , rudder and hull)
thanks for the help
Daniel
pretty sure the parts list spreadsheet has the required zincs. if you are having a diver do it, they often have all you need in their van already. my trim tabs zincs are not standard so having a diver with different types available was handy.
Here's my spares list from factory for my 2016 R-21EC
Anodes
Prop zinc size C-shaft Dia 1" Mfg# CMPNZC #32947
Rudder zinc Mfg# CMR03 #51152
Shoe zinc Mfg# CMT20 #51154
Thruster anode Mfg# SM31180A #380909
Engine parts (Volvo 30HP diesel engine)
Impeller kit #21951344
Oil filter kit #3840525
Primary fuel filter #3581078
Secondary fuel filter #861477
Engine belt #3812159
Boat parts
Navigation light bulbs-- (same as anchor bulb) #90200-7 (Qty 2)
Wiper blade refill #31112B
Mast wing nuts (Qty 2) #194-016 tac screw (it's very useful to have these)
ANL Fuse (Thruster) 150 amp #SMAN150
Bilge float switch #36301
Bilge Cartridge 750 GPH #28572
Thruster shear pin #SM32050
Thanks everyone that should do it.
