This is a bit of an old thread, but probably growing in relevance as these boats age.
Short version - it was very possible to replace the mounts in a Yanmar equipped R-27 classic without removing the engine.
Long version - As mentioned earlier in this thread, take height measurements of all four mounts for rough alignment later. Also, part the shaft flanges and check for alignment before starting disassembly. Who's to say that it was aligned when you started?
The rear mounts were a piece of cake. Easy to access and this end of the engine was pretty light. I used a 4x4 across the engine compartment and a 2000lb rated ratchet strap to do the lifting. There was a lifting eye in the middle of the transmission housing, I used this and was able to do both mounts with a single lift. Made sure to wedge the engine up with some wood pieces and kept clear of the lift strap, just in case of failure.
The forward port mount was pretty easy too. Again, the 4x4 was placed across the engine compartment up on the steps to ensure sufficient lift space. I looped the strap through the upper alternator mount bracket for the lift. Lowered the adjuster nut on the rear starboard mount so that the engine could rock over on the forward starboard and rear port mounts. The front of the engine was pretty heavy, but well within the capability of the lift strap.
The forward starboard would have been pretty easy if it weren't buried under the heat exchanger and intercooler. I suggest removing these as it is probably time for an internal cleaning anyway. The heat exchanger was easy to get off. The intercooler had some bolts on the bottom that were tough to access. If you're in that far, might was well get the transmission oil cooler out too. All of these were coupled with single hoseclamps so all of those got replaced on the way back together.
With all that out of the way, the strap was looped around the forward starboard mount bracket, the rear port adjuster nut lowered and the engine rocked over to get the mount out and back in.
Findings - All lag holes were intact and did not require any rework. All mounts showed considerable rust on the lower flanges. All of the adjusters were at the uppermost extreme of their travel. There was some evidence of leakage from the forward cover of the intercooler, this was near invisible without removal. Both the intercooler and heat exchanger were dismantled for cleaning and resealing (another story), there was considerable blockage with hard mineral deposits.
Improvements made - There are several threads on here discussing rusting of the engine mounts. The mounts sit right on the stringers where water can/did pool. Considering that the old mount adjusters were maxed out (not great), I made up 1/2" fiberglass spacers and got longer lag bolts. The mounts now sit up off of the stringers so water will not pool around them. Of course, they are also cold galvanized and topcoated with matching Yanmar paint for good measure. The adjusters are now in the middle of their range as well, per the installation instructions. The cooling parts were cleaned with Barnacle Buster and a 3/16" aluminum rod and reassembled with new o-rings and grease. Some good tips here -
https://www.sbmar.com/articles/cummins- ... intenance/
Anyway, it was a good couple of days of work but nothing overly challenging. Looking forward to many more years of quiet and cool running after this work.
have fun,
Brendan
