2islanders
- Dec 17, 2018
- C-26
- FMLR2501D112
- Emily Rose
We have a Yanmar 4BY2-150 with 1400 hrs and have been battling an obvious overheating and relay socket failure at one terminal. The pump draws 8.1 amps which I believe is the spec for that pump. Replaced the socket with a BMW OEM socket and it failed again after 19 hours. The wire feeding it seems very light and wonder if that is causing an overheat at the spade terminal.
Has anyone else run into this and/or solved it ? I see some older posts that looks like there have been similar issues but wonder if they reoccurred? Any advice would be appreciated
Tom
Tom
