watson1987
- Jun 7, 2021
- R-31 S
- FMLT3119L718
- Clifford
Last night, I plugged into the podium and immediately tripped the main ELCI breaker. That has never happened to me before. I heard the faintest click when I flipped the breaker on the podium, which led to removing the cockpit table and flipping up the aft seat to see the breaker had tripped.
Before this event, I had been running the inverter for 6+ hours, with my Starlink going at the dock, without any issues.
After turning everything back off, resetting the breaker, and trying again, I immediately here "pop pop pop pop pop" and flip the breaker off manually this time - for some reason it didn't trip itself. I immediately started to smell electric burning. I unplugged the shore cable entirely and turned off all my AC breakers. I tried to turn the inverter on via battery power to see how bad of a situation this was or what side of the system was gone (my fiance had the fire extinguisher out by this point). The meter on my AC panel immediately jumped to 'redline,' which is 150V, and after shutting the inverter back off, it very slowly came back to 0V (over 10-15 seconds - way longer than usual).
At this point, I realized our trip would be cut short, I fired up all the DC systems (engine, dash, radio, etc.), ensured things were working, and jetted back to our home marina just before sunset.
I picked up and installed a new Victron MultiPlus II 2x120V unit today, so less than 24 hours later, I'm back in business, hopeful to head back out for the rest of the week tomorrow. This evening I took apart the Kisae and found a portion of the PCB with black char and a few tiny metal shards nearby.
PHOTOS
https://www.icloud.com/sharedalbum/#B14G9Gd2NGyJcSk
PHOTOS
