110 power
Stardust
R-21 EC
Fmlc2839d616
Anybody know if there is a circuit breaker between the distribution panel and the Shore power plug. I have power coming in through the Sure power cord. But I have no voltage at the panel. Any ideas
Not sure where on your model but there is on mine. Mine is fairly close to the panel so you might be able to trace it back. I imagine someone with your model should chime in soon.
See if this helps—
Go to forum index. Then cut water technical bulletins. Updated owners manual. Then see page 11 for picture and 21 for diagram. Your boat might be newer model but gives you a start.
Hello,
I would check GFI which is located under the galley stove/microwave. This would cause the issue you are describing. Feel free to email me if you have any additional questions.
Kevin Lamont
Also check ELCI- under aft seat on our 31 near inlets.
