Alpina
- Sep 11, 2020
- C-30 CB
- Alpina
2019 RT 29CB, LE package. Purchase used in May 2020.
Have steady consistent 120V on AC Main Panel 2 on both shore power and generator. Able to run air conditioners, no problem.
Two nights ago, I come back from an outing and noticed that the 120V on Main Panel 1 kept coming on and off sporadically. I switched the power cables and had the same issue. On both shore and generator power. The power meter needle reflected that. I did a little trouble shooting but will go back tonight as I wasn’t fully equipped. I did use the inverter to run the microwave for 3 min total while on the boat.
I was hoping for some help to get me a jump start as the wiring diagram doesn’t have the 120V side.
1) Where does the shore power go to first? I am assuming to the switch that allows you to selected Shore/Off/Generator power. Is that accurate?
2) where does it go to second? Assume I am accurate in #1), for the AC Main 1, does that go to the inverter/charger and then to the AC Main 1 30A circuit breaker, and then to the individual circuits? Does the second line go to the AC Main 2 30A circuit bypassing the inverter/charger all together?
If assumptions above are all correct, is the likely culprit the inverter/charger? For those that replaced their, did you put in the same brand Kisae or another brand and why?
Thanks in advance for your feedback.
Franco
Franco
