scross
- Jan 30, 2015
- C-28
- FMLC2831A717
- R-25 Classic - Sold
I know replacing the fresh water pump has been discussed many times before. Haven’t seen the answer to this question yet though.
On page 32 of the Cutwater 28 owners manual it says that the wiring to and from the fresh water pump (labeled Water Pressure) is Brown/Yellow 10. I’m assuming that the 10 means 10 AWG. The stock fresh water pump is a 10 Amp pump with a 10 Amp fuse on the PDP Fuse Block.
I would like to replace the 10 Amp stock water pump with a 15 Amp Johnson Pumps 10-13329-103 Flowmaster Variable Fresh Water Pump.
If the wiring to and from the water pump is actually 10 AWG then I should be fine to use the existing wiring, install a 15 Amp fuse at the PDP fuse block and be good to go. The Brown/Yellow 10 wire exiting the PDP fuse block is labeled Fresh Water Pump and seems to be 10 AWG as indicated in the Owners Manual.
Am I missing anything?
