dougandnancy
- Mar 6, 2019
- C-248 C
- FMLT2550H708
Our new-to-us tug recently developed an alarming bilge leak. The bulk of the water seems to be coming out of a limber hole in a small fiberglass hump in the absolute bottom of the bilge directly under the transmission output. The leak is water and it appears clear, but as we are moored in a river I can't tell if it is external or internal.
The bilge forward of this limber hole appears to be dry, except when the flow fills the bilge enough to set off the forward (#2) bilge pump. Of course, that only happens because the sensor on bilge pump #1 recently went out, and yes, I did try cleaning it.
So, are any of you tugnuts familiar enough with the layup of these boat to be able to tell me from where the water out of this hole comes? Thanks for listening. I have found this forum to be a godsend.
Doug
Doug
