fishheadbarandgrill
- Jul 15, 2018
- R-29 Classic
- Non-Fluid Motion Model
- Sunfish; Vespa GTS 300 Super
- Sea Shanty
My macerator (Johnson) is mounted behind the salon air conditioner, behind the forward partition in the cave. I suspect my macerator has failed due to lack of use. I’m prepared to replace with a new Johnson macerator but I’ve read the installation instructions and it says that the pump must be installed at the level of the tank discharge... not a self-priming pump. I think that I have a post-delivery install and think it’s the same configuration as a factory install. I have a call into RT now to confirm. Do others have the same installation location for their R29 and same Johnson macerator. I’m thinking about replacing with a Jabsco because they are advertised as self-priming. Any priming issues with the Johnson pump at that location?
