walt2
- Aug 6, 2012
- C-26
- FMLR2508H112
- Northern Bights
I have an on going issue with the starboard cockpit locker not draining properly. I removed the Trim Tab pump/reservoir to access the drain cover at the back. It was not blocked and I removed the cover. I was able to push a 1/4 tube about 3ft into the drain. When I blew in it, I could hear bubbles come up fro behind the hot water tank. I then accessed the back compartment, starboard side and noticed that the weep hole was dry. I was able to push the 1/4 tube about 1 foot into this hole. when I blew through the tube it appeared dry. How is the connection made from the locker drain to the lower weep hole? Any insight on how this could be remedied would be appreciated.
