2014 R25 Aft Bilge Pump Fuse Location
P&GRidgeway
C-26
FMLR2528C414
I have not been able to locate the fuse for my 2014 RC25 aft bilge pump. The pump has stopped working. Appreciate your assistance.
Peter
Wiring tends to change. There may be a group of inline fuses bunched together below your house switch. Just because the pump stopped working it may not be the fuse. The pump could be burned out. Did you turn on the manual breaker/switch at the panel? That will confirm the pump is good and then the next would be the auto on fuse. If that is good, it could be the sensor.
The inline fuses KnotFlying is referring to are mostly likely black and about the size of a matchbook (remember those?), all tucked together under a RED Service switch. HTH, Gary
Thank you both for your assistance. Located the fuse and it was good.....cleaned the sensor.....appears that the motor is shot. The company offers: 500gph, 750gph. and 1000gph cartridge replacements. I'm thinking of going with the largest. Any thoughts on the size of the replacement pump?
As long as it fits go with the largest. By the way, did you turn on the switch in manual mode? If not do that to make sure it is the motor before replacing.
