2016 R-31S- Where is the fuse for the fresh water pump?
Bpwicks
R-31 S
B-Pod
The water pump that supplies fresh water to the galley and head sinks stopped working with no warning. No problems with the pump previously. I suspected electrical issue (?fuse) but I cannot identify where/which fuse might be the culprit. I cannot fine “fresh water pump” listing on any of the fuse diagrams in the Manual. Thanks for the help.
On our 2011 29, there is a breaker on the 12-volt panel as mentioned above, and there is also a fuse in a fuse block in the port-side lazarette below the inverter/charger.
For about a year and a half, we had intermittent freshwater pump outages that also caused the freshwater gauge and backlight to shut off. This was extremely inconvenient, as we have a freshwater flushing head. The outages would randomly come and go randomly. I finally found the problem; a negative ground cable that attaches to the bottom of the fuse block was loose. I tightened that up and have not had any freshwater system issues in the past year.
Hope this helps - good luck.
