Matty,Matty":3h4on518 said:...
If they have not changed it the location of the inverter is behind the wood panel that holds the circuit breakers. There is a small access panel but you really need to pull the whole panel to see it or use the reset button. If you have a 2020 you should definitely have the manual which has the specs.
Andrew Custis":n1h0u3de said:Hello Jeff,
We are now locating the inverter for our Lithium boats to underneath the galley. We keep the location where it is for the NW boats. Not the easiest to access but also not the worst. I’m pretty sure panels can be removed to gain access but I would need to check with the team for the easiest way as I have not personally done it. No plans on relocating electrical panels either. In regards to gauge of wire, this all depends on location and distance from battery. On my 23, I tucked my own inverter outside and underneath the lip of one of the cockpit hatches. Kept it close to the batteries but that also isn’t the best being slightly exposed to the elements.
Are you having issues or just looking to make access easier to reset the GFCI outlet?
Thank you,
