Dcsqatar
- Dec 11, 2018
- R-29 S
- Beautiful Red
I am experiencing the following bilge pump issues, and would appreciate any help.
1. Both pumps are Rule automatic model 27sa, 1100 gpm. I believe these are standard in all new Rangers.
2. Aft pump works via the dash switch, but does not come on when the bilge is flooded, and it is not doing its 2.5 minute automatic check.
3. Forward bilge pump is doing its 2.5 min automatic check, but is not pumping. It hums but is not moving water. Hard to tell if its float switch is working since the pump is not pumping.
4. I tried my best to clean both pumps by removing from hull mount and cleaning surfaces with soap via a toothbrush. Impeller is free spinning in both pumps.
5. I checked both 7.5A fuses and they have continuity.
No manual was provided with my new boat, so I downloaded one. It does not speak to troubleshooting or maintenance, so I went to Youtube but could not find anything particularly helpful.
I also do not understand the pump wiring. I believe both pumps are directly powered via the thruster battery banks, but interestingly both pumps work from the dash switches even if the fuses are removed. Switches light up and pumps work (or try to in the case of the forward pump) even with no fuses installed.
Anyone have any ideas? Maybe I have to completely remove the pumps and check/thoroughly clean them, but it is a challenge given the aft pump's location under the shaft and the forward pump in the tight space in front of the engine and therefore I have been trying to avoid doing this.
