2021 R-27 bilge pump location
New Adventure
I know where the aft one is and the one under the step, where is the 3rd and access as well as fuse location
On our 2023 R27, the mid-ship bilge pump is located at the forward end of the center cockpit storage lazerette and just aft of the fuel tank divider.
The fuse should be in the compartment as the lower right on aft bulkhead in the cave. It may take a bit of boat yoga to access it.
Thank you for the reply
I didn't see the fuse there but will look again next time I'm at the boat, did see one in the bathroom fuse panel but it was fine
(center cockpit storage lazerette) close to the freshwater pump? sorry a little confused by this description
On our 2023 R27 the midship bilge pump is located at the forward end of the center cockpit compartment - as a longtime sailor our storage compartments were called lazerettes.
In our center cockpit compartment there are 2 bilge pumps, the A/C pump, and the two through hull sea cocks.
Hope this helps!
