2021 R25 pumpout adapter
jlstanley
New Bern, NC
R-25 (Outboard)
FMLT2557F121
2021 Ranger Tug R25 LE OB
Good Trouble
Can anybody tell me the correct pumpout adapter needed for my 2021 R25? Thank you.
Judy
You want the 1¼” inside diameter pumpout adapter with 11.5 threads per inch. I bought one from Fisheries Supply.
Jay
Thanks Jay. Much appreciated.
When we were at Lake Powell a few years ago they didn’t use the standard pump out setup found at most PNW marinas. I was told many fresh water lake marinas require the adapter. We had to use one of these:
CAMLOCK - 125F POLYPROPYLENE CAM & GROOVE FITTING; 1-1/4 INCH MALE ADAPTER X 1-1/4INCH MALE NPT https://a.co/d/i2T9kcT
And some 1 1/4 “ ABS or PVC NPT (11.5 TPI) male threaded (both ends) nipples.
and a double female threaded 1 1/4” coupler.
If you want to get fancy you could use a 90 degree coupler. Which is what we did to get a better angle to the pumpout hose. We have used the adapter on both a 2009 R-25 Classic and a 2017 C-28 with success.
Should be under $20 total.
We have used our adapter in the PNW as well at Powell River, BC that did not have the standard fitting when we were there last year.
Thanks for the info Glider4.
