2022 R27 Ranger Tug 300OB water heater
Satu-Lagi
Satu Lagi
Ranger Tug,
From the 2022 R27 specification sheet, my hot water tank is a 5.3 gallon isotemp and does not have any bypass valve for taking the tank out of the freshwater system. My hot water heater tank has failed (leaking) and my freshwater pump, I think is a (3GPM Shurflo Aqua King model) ? will not prime and continues to run.
How to I drain the water heater correcting ? and how to I stop the flow of cold water coming from my freshwater tank (I just filled) from continually spilling into my bilge area ? after I remove the hot and cold water lines from the water heater ? is there a shut off value before the intake on my water heater ? I am not seeing one.
thank you
