2024 LE MPPT
JMarshallR25
Santa Barbara, CA
R-25 (Outboard)
FMLT2537D424
NISSE
It appears that 2024 LE models are including what looks like an EPEVER DuoRacer MPPT Dual Battery solar charge controller instead of the old MorningStar SunSaver Duo. This product is visible in the "cave" in user Submariner's R25 tour video from the 2023 Seattle Boat Show. What is the incoming solar capacity in watts for this product? Can it handle a second factory panel in a "plug and play" fashion with no other changes?
It can support up to 390W for a 12V system. You can add a second panel, but it is not plug in play. The same ground and hot wire going to the panel already on the boat can be spliced into with the wires from the new/second panel.
