21 EC Bilge pump
BessieO
C-24 C SE
Bessie O'Donnell
The bilge pump on my 2006 21 EC does not appear to be working. I felt around it for clogs and it went on a few minutes later but does not appear to have kicked in since. Rainwater is collecting in the bilge.
Is there any typical reason for this and/or if the pump needs replacing, what's the proper pump to put in there?
Have you tried to remove the inside part of the pump to make sure it’s clean and free of debris? Check wiring connections and the fuse. Does the rocker switch light up when you press it?
Solved it. Loose negative wire.
