TylerFromEverett
- Sep 27, 2019
- C-24 C SE
- Kimberly Marie
Hello Fellow Tuggers,
The battery charger on my 2014 21ec is being weird. It’s display is showing 0.0 volts and amps when plugged in, the fan runs constantly when hooked to power and the “conditioning” light stays illuminated when plugged in. I’ve check the two inline fuses and they’re good. I did a hard reboot on the charger. II checked the house battery with a multimeter with the charger hooked up to power and it shows 11.2v the starting battery shows 12.6v so I’m assuming the charger isn’t charging the batteries. The engine charges the batteries when it’s running. Any ideas? Relay? Charger failed? It’s a Pro Mariner 1220p.
Thanks for your help!
