RProffer":rqxke8nm said:
I don't know if you missed it, but there is a 150 amp fuse for the bow thruster on the R21-EC. It is located under the stbd bunk cushion right next to the on/off switch for the bow thruster, mounted on the aft bulkhead for the bunk. If you leave that switch in the ON position all the time, then that whole circuit is protected by the fuse all the time. An additional fuse/breaker is not required. If you decide to install an additional circuit breaker or fuse, then make sure it is a 150 amp device - not more or less. I don't know too many people who would go to the trouble to lift that bunk cushion to turn the switch on/off every time they want to use the bow thruster.
Hello Rick,
I respectfully disagree with you. There are times when the forward-located ANL fuse WILL NOT protect the circuit.
I'll explain...
ABYC standards require all main DC circuits to be overcurrent protected (fused) within 7 inches of the battery. The starting cable being one exception. The reason for locating the fuse CLOSE to the battery is to protect AS MUCH OF THE CABLE AS POSSIBLE. Protect the cable from overcurrent situation, that is. (ABYC 11.10.1.1.1)
To be clear,
the fuse protects the wire...
not the devise. Therefore,
the fuse is SIZED according to the current carrying capacity of the conductor. But I digress...
A fuse, like the ANL on the 21EC in the forward compartment, protects the portion of wire BETWEEN the fuse and the devise (thruster in this case). But there are times, such as when there is a dead short along the cable BETWEEN the battery and the ANL fuse, then that fuse becomes USELESS, and the overcurrent situation will continue unabated (FIRE being the end result) since the fuse does not see any overcurrent. If you consider this situation, even if the fuse blew, the dead short would persist since it occurred "before" the fuse along the course of the wire. The house/thruster cables chafing as they pass by the vibrating engine on their way forward is what sparked (pun intended
😉 ) this discussion. Shorts can happen on any boat; overcurrent protection (fuses) will prevent disaster/s.
IF the overcurrent (or short) occurs between the fuse and the devise, then, YES, it does protect the "downstream portion" of the circuit. Well, there again, the fuse would blow, and current flow would stop 'after' the fuse (between the fuse and the devise) but the portion of wire BETWEEN THE BATTERY AND THE FUSE would remain energised...and UNPROTECTED (from overcurrent or a short).
The emphasis, and goal of the ABYC standard, is to protect AS MUCH OF the conductor as possible by locating the fuse CLOSE to the battery. HENCE the MRBF discussion above.
I removed the ANL under the stb bunk and replaced it with an MRBF at the battery terminal.
Stay safe my friend...Fuse early and often
/david
