BB marine
- Feb 1, 2016
- R-21
- Non-Fluid Motion Model
- Mainship 34 Pilot
- PORT-A-GEE
I had the pleasure of meeting another Cutwater owner on our 1st Loop segment . He noticed my engine vent screen came loose from the stainless frame work and stated his was in the same condition.The screen was pulled away from the Frame work the day we took delivery and the dealer made an attempt to repair it with no success. It's on my todo list. I stated I will repair it when I pull the air boxes off to find a water leak that I have on the starboard side. I thought that the water may be coming in around the air inlets that vent the engine compartment. My plan was to fix the water leak and possibly increase the inlet size and attach vent hoses to them to direct more air flow to the compartment.. After this conversation I received an email saying the vents that you thought are venting your engine compartment are just for looks !
1) Is this a true statement ?
2) If so where and how does the engine compartment get vented for fresh cool air for an efficient running Turbo Charged Diesel engine , heat reduction and odor?
3) If it is vented in the cockpit somewhere, how is it vented with a full cockpit enclosure? And will it get enough air for the air induction for the engine, cool the compartment and vent odors, (CO) and other Gases or vapors that may be present.
Issues that I have encountered mostly while doing the trip because of extended hours of cruising.
1) Engine compartment temperature extremely warm. My engine temperature maintained a running temp of 180 degrees with average days of 8 to 10 hours run time. I feel that with an engine running at this temperature and all the sound deadening insulation the compartment seemed to be close to that temperature.
2) All the engine compartment insulation started coming loose and some of it fell off .
3) I noticed waste tank orders in the engine compartment and cockpit storage compartments when I opened the hatches.
4) The bilge area under the engine/reverse gear, at the end of the day would be dry, It has always had a small amount of water presumably from the shaft packing. The heat I believe evaporated the water.
I'm not complaining about these issues or the boat. Our Cutwater performed flawlessly on our trip. We purchased this boat to do extended cruising like many others have. I realize that some alterations may be needed . I have time to address this vent issue if I need to.Many Cutwaters/Tugs do not have enclosures. Then there are many that do. What is the air reduction with the enclosure ? What are the side vents for? If they do vent the compartment can the size be increased? If they're not used is there a reason why? Thank you for any information that you can provide.
Brian Brown
26 Cutwater
PORT-A-GEE
Brian Brown
26 Cutwater
PORT-A-GEE
