First off, my wife and I love our R31S. I find it to be near perfect today even after over 4 years of use. But, it did have a significant number of new boat issues - 25 of them in fact.
Still, I highly recommend Ranger Tugs boats and their great after market service. Andrew Custis and his technicians have been invaluable days, nights and weekends.
Unlike a modern day car where hundreds of thousands for many models are built each year with very standardized processes and much of it automated, a boat is almost custom built with very small production numbers. So, I have different expectations about delivered quality for a boat. I've owned 2 different diesel-pusher motor homes which also have had a significant number of new motor home issues. They are also near custom built with small annual production numbers.
I keep very detailed notes on all issues and maintenance for my cars, motor homes, and boats. If you are willing to endure my tedious and lengthy list, read on:
Summary of ALL 2014 R31S Problems
1. Scratched counter top
STATUS: RESOLVED by Wefing’s Marine dealer before delivery
2. Scratched stove top
3. Misaligned prop shaft to transmission
4. Broken gears in spotlight discovered on day of delivery
STATUS: RESOLVED quickly by having Diversified Yacht Services through warranty payment to install the replacement spotlight sent by Andrew Custis at Ranger Tugs
5. Broken bow thruster joy stick occurred on day of delivery
STATUS: RESOLVED quickly by having Diversified Yacht Services through warranty payment to install the replacement thruster controller sent by Andrew Custis at Ranger Tugs
6. Marred leather strap for gullwing seat on starboard side, found upon day of delivery
STATUS: RESOLVED. Dale quickly received replace leather strap from Ranger Tugs.
7. Clogged fresh water pump strainer – tiny globs of PVC cuttings – occurred immediately after delivery
STATUS: RESOLVED by Dale removing the globs after Ranger Tugs technician sent replacement strainer at no cost, since Dale had trouble getting the old one apart without breaking it
8. Fresh water pump cycled about every 2 minutes, occurred immediately after delivery
STATUS: RESOLVED quickly by Andrew Custis of Ranger Tugs authorizing Diversified Yacht Services through warranty payment to repair by finding and fixing the leaking cockpit shower hose.
9. Upon delivery, missing tan Sunbrella coverings that you can’t see through for: (a) 3 rear cabin windows, (b) rear cabin door, and (c) windshield.
STATUS: RESOLVED quickly by Wefing’s Marine dealer sending replacement Sunbrella coverings
10. Upon delivery, missing recessed toilet paper holder in head.
STATUS: RESOLVED quickly after receiving recessed toilet paper holder from Ranger Tugs and installed by Diversified Yacht Services through warranty payment.
11. Upon delivery, both TV volume levels were too low to hear well even at 100% volume setting.
STATUS: RESOLVED: Common problem with these type TV’s, Dale now attaches separately powered portable speaker to the TV.
12. Shortly after delivery, discovered all 8 flush-mount windows had gooey, sticky sealant.
STATUS: RESOLVED quickly. Received replacement sealant from Ranger Tugs who authorized Diversified Yacht Services through warranty payment to replace all the sealant on all 8 windows.
13. Discovered shortly after delivery, aft A/C next to ¼ berth did not drain. Hence, it spilled onto plywood and monkey fur resulting in mold.
STATUS: RESOLVED quickly when Ranger Tugs authorized Diversified Yacht Services to repair by discovering sagging drain hose which was fixed by tying up the hose to eliminate sags.
14. Discovered shortly after delivery, V-berth A/C periodically iced up and quit working.
STATUS: RESOLVED quickly when Ranger Tugs authorized Diversified Yacht Services to repair by changing the thermostat control settings
15. Discovered when fixing the A/C drain problems, leaking sump pump corrugated hose connection at the sump. Sump is under the aft section of the V-berth then under a piece of starboard.
STATUS: RESOLVED quickly by Ranger Tugs authorizing Diversified Yacht Services through warranty payment to attach the hose properly.
16. Discovered after the first rain after delivery, leak in the cabinet above the helm.
STATUS: RESOLVED quickly when Ranger Tugs advised that the starboard running light might be the source of the leak, so Dale removed the attachment screws and re-caulked around them.
17. Discovery a few months after delivery, mid berth port light latch so loose it unlatched itself while underway. No obvious adjustment. No solution provided by Ranger Tugs.
STATUS: RESOLVED: Dale took the latch apart and put a very thin plastic shim in the latch to force it to close more tightly.
18. Discovered about 1 year after delivery, mid berth port light leaking around a screw causing a stain on the monkey fur.
STATUS: RESOLVED: Dale replaced and properly caulked around the screws.
19. Discovered about 9 months after delivery, three screws broken off at the top of the cabin where the blue cabin trim piece attached, clearly from over-tightening when built.
STATUS: RESOLVED quickly by Ranger Tugs authorizing Diversified Yacht Services through warranty payment to attach the trim properly and seal the screw holes.
20. About 2 years after delivery, I received ignition warning that there was a fault and the engine would not start.
STATUS: RESOLVED quickly. On a weekend, Dale called technician Kenny Mars at Ranger Tugs who walked Dale through the process to reset the ignition issue. No problems since.
21. Discovered after 3 years from delivery, seeping sea water causing rust stains inside the hull below the engine exhaust port.
STATUS: RESOLVED by Dale having a replacement port installed and having a bonding wire attached to the port to minimize crevice corrosion in the future.
22. About 11 months after delivery, stern thruster shear pin broke.
STATUS: RESOLVED, by Dale replacing the shear pin.
23. Discovered about 1 year after delivery, 3 of 4 wipers sometimes do not work on the UP position. Then if I press the DOWN position they work. Immediately afterwards, they then work in both UP and DOWN position.
STATUS: OPEN. Ranger Tugs suggested the switches might need to be replaced.
24. Discovered about 3 years after delivery, the plastic catch broke that holds the strut for the mast to the forward deck. This is the strut that is used when the mast is folded down to hold it in place.
STATUS: RESOLVED. Richard in Ranger Tugs parts sent a new one at no charge for Dale to install.
25. About 4 years after delivery, the GPS stopped working.
STATUS: WORKAROUND. On a Saturday night, Dale texted Andrew Custis at Ranger Tugs who walked him through diagnostic procedures so that together we worked around the issue by powering off the house batteries to re-set the NMEA 2000 network. No problems since. The root cause of this problem is still a mystery.
26. On 3/16/2016, received notice of Service Bulletin 21-0-7 for the Volvo D4-300 engine – simply a label issue.
STATUS: RESOLVED by Diversified Yacht Services performing the work.
27. On 1/2018, received notice of “Recall Campaign. R0031, D4, D6. Alternator harness inspect” for Volvo D4-300 engine.
