scross
- Jan 30, 2015
- C-28
- FMLC2831A717
- R-25 Classic - Sold
Alpina,
I’ll be interested to see the responses you get to your questions. I had similar questions so I emailed Victron Energy about my 100/20 controller. The reply was that anything over 100 volts would damage the controller so it was important not to exceed 100 volts. As to maximum amperage, the controller will take more than 20 amps for input but only “pass” through a maximum of 20 amps of charge to the battery. I have a 15 amp fuse between the panel and the controller that would trip before the controller would see 20 amps on the input side.
The 330 watt panel I was interested in is rated at 69.7 volts open circuit and 6.07 amps short circuit current. Panasonic recommends a 15 amp fuse between panel and controller.
Based on that, I believe I am ok with the 100/20 controller and the 330 watt solar panel.
All you electric experts please correct me if I’ve missed something!
