hxschiller
- Jan 22, 2014
- C-24 C SE
- FMLT2111G809
- Impulse II
There are two drain devices on the Yanmar 3YM30 to drain old coolant. The one that's on the starboard side of the engine block and seems to be somewhat obvious; simply unscrew a bolt. However, the other one is on the port side of the engine in the middle of a (very circuitous) coolant hose in what appears to be a rubber TEE fitting. Just how does one drain coolant through this thing? Is there a special tool? Must I remove the clamp on the TEE?
