Submariner
Channel Surfing
- Feb 2, 2020
- Everett, WA
- Website
- www.letsgochannelsurfing.com
- R-27 (Outboard)
- FMLT2702C021
- Non-Fluid Motion Model
- https://tinyurl.com/yrv84xdm
- Channel Surfing
Does your Garmin 8612XSV report GPH and GPS Speed, yet only reports 0.00 for mpg?
Does your boat have a Yamaha outboard?
Did this use to work before April of 2021, and stop working after a firmware update?
Here's the answer and it's complicated.
The Yamaha Command Link Plus is what's installed for the outboard. Technically, that bus is J1939.
The network that connects the devices all together is the Nema2000 (N2k) bus. The Fusion Radio, Garmin Chartplotter, VHF Radio, Autopilot, all connect via the N2k bus. To connect the engine from J1939 to connect to the N2k bus, a Yamaha Command Link Plus gateway is required (MAR‐ GTWAY‐KT‐00). This converts engine data from J1939 to N2k.
I spoke with Garmin, the problem with MPG not reporting on the 8612 chartplotter is the Yamaha Command Link Plus Gateway. To bypass/remove the Yamaha Gateway, perform the following: There's a Garmin cable one can buy for about $30, "Yamaha Engine Bus to J1939" cable. This plugs into the J1939 port on the back of your chart plotter. The other end plugs into the cable that you unplug from the Yamaha gateway.
This is how you bypass the Yamaha Gateway and have the engine plugged directly into the chartplotter. This solves the mpg reading on the 8612XSV Chartplotter. It will work.
However... If you have the Lenco Autoglide or are planning to install the Lenco Autoglide, the Autoglide will not work without the Yamaha Command Link Plus Gateway. The Autoglide requires engine RPM data, which is only available on the N2k bus if the Yamaha gateway is installed. The Garmin Chartplotter will not take engine data received on J1939 to send back out on the N2k network.
My 8612XSV stopped reporting mpg sometime earlier than April of 2021. I have the Yamaha Command Link Plus gateway for the Yamaha F300. I bought the Yamaha Engine to J1939 cable. I also have Autoglide installed. I tested this today.
My solution remains the same. I use the Yamaha display to see MPG used solely for adjusting engine trim. On my chartplotter, I watch GPH, and can not display MPG. I need the Yamaha Command Link Plus gateway for the Autoglide to function. I can't use the Yamaha Engine to J1939 cable.
Did your boat come with a Yamaha Engine Gateway?
My 2021 RT27-OB came with the Yamaha gateway. I recently helped another boater install Autoglide on their brand new 2023 RT27-OB. Apparently, the factory has stopped installing the Yamaha Gateway and instead, installed the Yamaha Engine to J1939 cable which plugs directly into the Garmin Chartplotter. MPG reading works on the chartplotter.
If you're considering adding Autoglide to your new RT (outboard) (as I assume this info is the same for an RT23 and RT25), you will want to verify whether your boat came with the Yamaha Command Link Plus gateway. If not, you will need to buy and install one to complete your Autoglide installation. Installation is easy, but the gateway adds additional expense.
