I am doing some electrical upgrades to my 2011 R27 and would like to bring all the new wiring into compliance with the current ABYC standards that have changed or are new since the boat was built.
One point I would like some clarification on is the overcurrent protection for the conductors between my batteries and the new battery charger.
Reading ABYC 11.10.1.1.1:
Then I read 11.10.1.1.2:
My charger is fused, so I believe that meets the "overcurrent protection within the charging source, but I'm also now thinking that if I have a 18 inch conductor between my battery and charger, the internal fuse on the charger doesn't count as meeting 11.10.1.1.1 an I'll need to add a fuse at the battery end of this conductor as well.
Am I interpreting this correctly?
I was wondering which device one would consider the "source of power" - since when the charger is active, it is a source of power, but the battery is also considered a source of power for most (if not all) other circuits.Overcurrent Protection Device Location - Ungrounded conductors shall be provided with overcurrent
protection device(s) within a distance of seven inches (178 mm) of the point at which the conductor is connected to
the source of power measured along the conductor
(I added the bold for emphasis)In addition to the provisions of E.11.10.1.1.1 the ungrounded conductors to a battery charger, alternator, or another charging source shall be provided with overcurrent protection within the charging source, or within seven inches (178 mm) of the charging source, based on the
