AC in Cutwater30
Gerr413
Cutwayer 30 s
Hay jude
C3030k516
Is there a way to have the ac fan come on and off. I hear the compressor on and off. Is there a online manual for the switch controller that operates the A and 1-6 speeds and temp.
Thank you Gerry
Thank you Gerry
Which unit do you have? This is definitely a setting on mine in the programming menu. You can set the fan to cycle on/off along with the compressor.
Sent from my iPhone using Tapatalk Pro
Idk what brand they put in the c30 but it has a 12 and 16kw unit with the two remote switches, I would like to know how to operate the switches correctly and there is no brand name on the switch.
The switches have no brand name, but it's a 12 -16 kW ac on a c30, the switch is a mystery to me, with no instructions.
Thank you Gerry
Gerry,
The AC units we are currently using in the C30 inboard diesel is made by Webasto and model is FCF Marine A/C 16000BTU. They have all their manuals online and also have a great customer service line you can call if you are unable to find what you are looking for. Hope this helps.
Thank you,
Kevin Lamont
