First of all, I am sorry that you are dealing with this. I know you had emailed us directly and I put you back in touch with Kevin Lamont. We also know that this was first brought up when the boat was purchased a few years ago but it appears it wasn't properly addressed and it wasn't rechecked for the past year or two.
Because of locations, it can be tricky to make sure that these hoses are properly routed with a downhill swing. We also know of many clogs due to barnacles and other creatures that run through the system. Many people in the south run barnacle buster or similar additives to keep these clear. Regardless, more than just the hose needs to be checked and identified.
We are not perfect as no company would be but we do take pride in everything we do. We have extensive checklist we run through and this is an item that is on our checklist. Do we miss it? Of course just like missing other parts that should have been done correctly. We also spend a significant amount of time teaching and hope our dealerships do too and try to explain all of the things that need to be looked after and watched. We improve our quality and boats every day and if I go back in history from the time I started with the company nearly 15 years ago, we have made significant improvements to the boat and will continue to do so.
Our focus is not just pumping boats out the door. Just so we are clear, we have a process which includes the following.
1. Our customer service team takes every boat to the water. We perform (along with the shop) an extensive on water test. We document any issues and bring the boat back to the shop.
2. The factory then goes through the list and corrects any known issues found.
3. Once the factory gives their ok on the repairs, we then come back and check again to verify everything was done.
4. Once it arrives to the dealership, they should be performing an extensive Pre Delivery Commissioning process in some cases which are not free. The dealership would then note any issues that they found, work with the factory and receive reimbursement for any repairs they make.
5. After that, the dealer is provide the same delivery experience we offer from the factory which consists of two full days on the water to go through the entire boat on and off the water.
Yes, we still make mistakes, mistakes are found but we really try to avoid many of them by following these processes. We enjoy and appreciate the feedback to continue to make a better boat for our owners.
Thanks again for posting,
