scross
- Jan 30, 2015
- C-28
- FMLC2831A717
- R-25 Classic - Sold
Need advice on how to install a 12 volt cigarette socket receptacle in the cockpit of our RT -25 Classic. Most (all?) of the newer boats have them as standard equipment. I would like to install the fixture on the port side of the bait well and run the wires down to the battery compartment on the aft port side. I do not want to run wiring all the way to the helm if possible.
One of my many weak areas is designing electrical systems. I can follow instructions however. I know this 12 volt socket will need to be fused. I will not be running anything that requires high amps off this socket.
I am assuming 10-12 gauge wiring will be more than sufficient for this short 6-8 ft run. I have sent Richard at Parts@RT an e-mail asking which brand of socket RT uses in the current production. I want this socket to be completely watertight when not in use.
Here are my questions:
What size and speed of fuse is appropriate for this type of circuit? (Guessing fast 2-5 Amp fuse)
Is 10-12 gauge wiring appropriate?
I was planning on connecting the fused circuit wires directly to one of the house battery’s terminals - is that OK?
Does this circuit need an ON/OFF rocker switch as well?
Is there anything I’m missing here?
Thanks in advance for the assistance.
