Hi, John. I also have a newer (2017/140 hour) Cutwater 30 and have noticed some problems which occur due to the lower end (cost) components used to build these boats. There are problems with the shaft seal, autopilot pump, bilge pumps, depth sounder, hoses, hose clamps and electrical components that possibly could have been avoided with the use of higher quality components (which would have resulted in a higher price for the boat).
So now that you have the boat, think positive and prepare a list of replacement components you want to install. Winter season is the ideal time to install these items. You can get a trend of what component problems other owners experience from this web site, prioritize these items and then get started. Try to replace them before they fail, no one want to have their boat laid up during the relatively short boating season that some of us experience, or worse yet, a frustrating breakdown while underway.
I will be installing a new Garmin Smartpump for the autopilot (the pump that came with the boat is overtaxed and a repeated problem reported by many others on this site) and a dripless shaft seal (mine has failed 5 times in one year I have owned the boat, resulting in a LOT of water in the bilge) this winter. Sounds like I should consider upgrading the bilge pumps, let me know if you decide to change yours out and what you decide to use.
