This is what I got from Webasto on 23 Jul 19 when I submitted the following question: I purchased a 2018 Ranger Tugs boat which has two Webasto Marine Air Conditioners with FCF controllers. I have been unable to change fan speeds in the AC mode. Please advise.
The control allows you to select different fan speeds. As long as the light moves between the H, M, L, and Auto and the fan does not stop, it is changing speeds. There is little RPM difference between the speeds, and depending on the application (number of bends, length of duct, etc) the blower may be working hard enough that there isn’t any noise difference. Since there are 3 separate motor power wires, if the blower does not shut off at a certain speed selection, there is nothing wrong and the unit is operating as designed.
Regards,
Webasto Technical Support Team
Technical Services
Customized Solutions
Americas
Webasto Group
Hope this helps!
