Air conditioner location
kjoverbeck
FMLT2704E415
Cheers
2015 R_27
Where is the air conditioner located ?
Thanks Kent
Others here may correct me but in my 2012 R27, I believe the condenser and evaporator are located in two locations: one under the co-pilot station near to where the thru-hull expells the sea water needed, and the other under the front of the v-berth where you should see a fairly large air intake grill.
Thanks for your reply.
Kent
Depending on the model of AC unit you may have everything under the passenger seat.
Thanks for the clarity Kenny. By the way, is there a Zinc in the AC system that needs replacing on a regular basis? And if so, where on my Ranger with a unit in the V-Berth will access to the Zinc be?
