Pretty sure it was a new 8 pin cable run directly to the chart plotter.Jfrano":2qj2vve3 said:Are the transducer cables a solid run to the Chartplotter or is there another connection point?
Ie can you reuse the P79 cable with the GT15 upgrade?
They used a glue on product called Stern Saver so no xtra holes needed.Headlee":5mytlyrp said:dexmot74
I would be interested to know more about how you mounted the transducer to your transom. I have a C-28 and have considered either upgrading to the Chirp in hull or going with a smaller Garmin unit in the cockpit and a transom mount transducer. Did you us a mounting plate (with 5200) on the hull or attach/drill into the transom? Thanks.
