On our 2011 R-27, the alternator died on a trip to Catalina. It was an OEM Valeo unit.
Upon returning home, I tried to get this unit rebuilt. It turned out that the regulator was not available. I found a Duralast #11083 at Autozone that was a Bosch with the right frame size, mounting and output specs. The difference was that the pulley offset was not compatible. I swapped the pulley from the old unit to the new and everything has worked fine for two years. By the way, this alternator was ~$100 and had a lifetime warranty from Autozone. Further research looks like Duralast #15058, 2009-11 BMX 335D, should have the correct pulley on it.
FYI, the engine needs around 9amps to power the fuel pump, computer, injectors etc. How do I know? We left Two Harbors under cloudy skies and showed a pretty good voltage drop on the engine battery. A few hours later, when we had full sun and 10amps out of the solar panel, the engine battery voltage stabilized. Nice to know that we had some electrical redundancy on board.
take care,
Brendan
