BB marine
- Feb 1, 2016
- C-26
- Non-Fluid Motion Model
- Grady White 208
- PORT-A-GEE
Yesterday I removed my 120V AC main breaker panel because I could not find my panel wiring schematics. I made changes to the panel when I installed and wired the Kisea inverter to the panel. There is a fellow Cutwater owner that had questions about the panel wiring and there has been questions about how to change the configuration form half the breaker panel to complete or add additional circuits to the inverter.
When I removed the panel I could see very easily what I had changed to complete my objectives. I also realized how the Cutwater owner was experiencing a continual Hot 120V to his outlet even when the main 30 amp breaker was off but outlet breaker on. The factory panel wiring is a bit sketchy relying strictly on a full functioning ELCI breaker and functioning inverter built in breaker and main breaker from the generator. The main 30 amp double pole breaker should not be relied on in its entirety. It is only protecting the neutral for the inverter side of the panel. When I installed the inverter I had changed this and this is why I was not experiencing the 120V hot to ground issue when the main breaker was off. I have spoke to other Cutwater owners and they too were also experiencing hot to ground 120V with main breaker off.
Here's really what my post is about. Inspect the connections at the AC panel. I wish I would have done this when I installed the inverter but I didn't. The fact is the only terminal screws that were tight in the panel were the screws that I tightened when I installed the inverter and the Blue Sea factory installed terminals were tight. The rest I didn't touch why would I ? Well as it turns out I should have. All of the terminal screws servicing the cutwater installed circuits were loose and the hot water heater breaker terminal was melted from continuous use and loose connection. The Battery charger breaker terminal was covered with oxidation due to continuous use with loose connections.
After seeing the burnt wires I inspected and tighten each terminal screw every screw inspected was loose the battery charger very loose finger tight and the hot water heater that melted I was able to remove that screw with my fingers once I got all the melted wire insulation off of it.
I have used the boat for four years without a 120V issue except the main shore power plug receptical connector screws were loose and the ELCI kept tripping. I should have checked all connectors then . The amazing part of this is the water heater worked the last time we used it. I'm sure this is uncommon but it happened. Electrical issues should not be accepted by manufactures. When it comes to QC electrical installations should be a strict standard. The most common cause of fires in boats is electrical.
I am adding electrical connection inspection to my list and checking them off as I go.
hot water terminal completely melted
The terminal next to the failed terminal (battery charger) had oxidation all around it was also finger tight
This is the battery charger terminal I removed it and cleaned the oxidation , inspected the crimp and reinstalled
This picture is blurry but it is the remains of the melted connector and the melted wire insulation from the indicator lights in the breaker switch.
Photo of some of the melted insulation and the indicator light terminal connector.
