Anode questions
lenz
R-23 (Sterndrive)
FMLC3030I819
Dosta
I have a 2019 Cutwater 30 inboard and I want to buy a set of replacement anodes prior to my upcoming haulout. I have the following questions.
- Are the anodes on this boat zinc or aluminum?
- Can you provide a list all the anodes and sizes installed on this boat?
- Are the anodes on the thrusters electrically isolated from the others (I assume this would allow a mixture of aluminum and zinc)?
You are in Washington. Ranger Tugs parts department can send you a full set of everything you need, easy peezy. I think you may have to go thru Andrew Custis still, the parts department does not seem to be responding still thanks to Covid. I imagine zinc are readily available, might be harder to find aluminum, but you should stick to all the same.
Thank you for the link Bruce!
You can find both aluminum and magnesium (plus zinc) anodes at boatzincs.com. They carry all sizes and shapes and are reasonably priced.
