CaptainT":3p47wrvq said:Where can I buy the oil pressure sensor?
rpmerrill":3kginixw said:I have only been left with two questions after I went through this in 2016.
1.) Why does this sensor cost so much? Lots of sensors on the market that cost a LOT less.
2.) Why do I get a low oil pressure alarm on the first 5 seconds of start-up but I didn't get an alarm when the sensor went wonky? I think I even disconnected the sensor while under way and got no alarms. AND I still got the start-up alarm with no sensor at all. I never got a good answer on that back in 2016.
scross":3kginixw said:I looked for a VDO auto sensor, which typically sell for $40 or so, but could not find one with the same size/thread pitch as the one on the Yanmar. I guess having everything proprietary is how Yanmar makes its money. If you find one from VDO please let us know! I would not mind changing a $40 unit every other year. Otherwise I’m just going to ignore the temporary high pressure readings if they recur and consider my boat haunted....
scross":2h132m18 said:Brian,
Thanks for the hoyetractor.com link to the thread adapter! You are a true gentleman and a scholar!! Just ordered one of the thread adapters for the spares trunk!
Even though our replacement genuine Yanmar $$$ oil pressure sender seems to be doing just fine it’s nice to know that I have less expensive replacement options should there be another sender problem in the future!
knotflying":2zd4eprv said:You may want to check the clearance from the top of the sensor in place and the metal cover that protects the engine. That fitting may push it up too much to clear the cover.
knotflying":3uza1g60 said:I took a look at the image you listed. I seem to remember that the 4BY2 unit had two terminals. Sometimes I take the position that since I am doing the work myself and saving money I will just go with the OEM part and bite the bullet.
rpmerrill":3uza1g60 said:2.) Why do I get a low oil pressure alarm on the first 5 seconds of start-up but I didn't get an alarm when the sensor went wonky? I think I even disconnected the sensor while under way and got no alarms. AND I still got the start-up alarm with no sensor at all. I never got a good answer on that back in 2016.
BB marine":1mum8t4i said:I agree with using the OEM. I would first elect to replace the sending unit with OEM. If I found the reliability of the system to be erratic then I would be looking for another resource . The issue with the OEM in many cases it fails and is pricy. There are many failures to the oil pressure sending not only on the Tugnuts forum but many others, along with the marine repair facilities. In some cases it's not as simple as just changing the sending unit. That was the case with the R27 that I spoke with, replaced the $200+ sending unit and it failed. For this reason some have elected to by-pass the OEM sender and use an after market. The custom sender from Catalina is a standard one wire sender with different impedance so a different gauge would have to be used. This is explained in the description of the sender. The Yanmar gauge will not work with this sending unit. This would be a conversion. If you want to use the Yanmar gauge you must use the OEM sending unit. If you elect to use a less expensive, conventional 12 volt sending unit that is common in the marine industry the custom sending unit from the Catalina web site is an option. If the adapter (listed in a previous post) allows clearance any standard sending unit will work but once again a different gauge will have to be used. I can't confirm this statement because I don't have a Yanmar but I believe as stated before in the previous post the Alarm system for no or low oil pressure will not be affected by not using the OEM oil pressure sender. There is a separate switch oil sender that activates the alarm.
I believe this may confirms that the pressure oil sensor and alarm switch sensor are different circuits.
rpmerrill":1mum8t4i said:2.) Why do I get a low oil pressure alarm on the first 5 seconds of start-up but I didn't get an alarm when the sensor went wonky? I think I even disconnected the sensor while under way and got no alarms. AND I still got the start-up alarm with no sensor at all. I never got a good answer on that back in 2016.
