Antifreeze for 25 SC. Yamaha D3 diesel engine
Sealeggs
C-26
Fmlr2521a414
SeaLeggs
Bought Sealeggs used. Needed some coolant which came with boat....Volvo coolantvcs premix. It does contain ethleen glycol. Volvo sells a yellow and a green coolent and state you cant mix the two. Can anyone advise which coolant comes in engine from factory. I need to order and quite honestly am confused and dont want to screw up. Thanks in advance. Bob
Volvo VCS Coolant....it's the yellow stuff
VP does have two coolants, green which is traditional inorganic acid technology (for the inhibitors) and yellow (VCS) which is new organic acid technology. VP's part numbers have changed..P/N 2145012 has been replaced by P/N 22567295. An internet search with this part number will yield several different suppliers.... There does seem to be some other products that cross reference with Volvo VCS:
Shell Rotella Ultra Extended Life Coolant (Yellow, Heavy Duty, Organic Acid, Extended Life)
Chevron Delo Extended Life NF (Yellow, Heavy Duty, Organic Acid, Extended Life)
Peak FINAL CHARGE® Global Extended Life Coolant / Antifreeze (Red, Heavy Duty, Organic Acid, Extended Life)
I probably wouldn't mix any of these, but with a complete cooling system flush and fill, these products seem to be reasonable substitutions.
