Brian: I checked out this AP issue today when out on the boat. I engaged the AP's feature of navigating a "Guide To" a specified destination by Name each time I tested.
There's no doubt that the 2013.603 or the previous software version has changed the way this feature works when using STBY to temporally change course and then re-engaging the AP to go back to its original course following.
In the past, when I performed this type maneuver the AP would bring me back to the original computed course and follow it. It did this at times with a fairly sharp turn if I had deviated several hundred feet away from the original course line. Knowing this, typically I would manually steer the boat back to be within several feet of the original course line and only then re-engage the AP.
What I now find is that using the above process to return to the original course the AP will immediately go into "Heading Mode" and follow the heading the boat was navigating at the time I press "Engage AP".
Even if I select Menu and Navigation Options to indicate I want to return to my original calculated course of "Guide To" I have to select "Recalculate", but that even does not work and the boat simply steers a course the boat was using when I select "Engage" on the Chart Plotter, and the AP display shows "Heading Mode".
These last two software versions (and I'm not sure one has done this) have royally screwed up what used to be a simple process for returning to the original "Guide To" course line after having to use STBY to make a temporary course change to avoid another boat or some object in the water.
I await for Garmin's Roger Archer to call me back to figure out if this was intended by the software updates or if it's simply an oversight by Gamin's software gurus and constitutes an unintended software bug that needs to be remedied/fixed.
Please keep us informed of what you find out from Garmin with your enquiry… and I'll do the same. Thanks. 🙂
P.S. I wonder if we can have Herb (Willies Tug) check this AP issue as well and say if he also agrees that the software updates have somehow 'screwed' things up for us.. I will PM him… 😉
